Hey guys, just curious, what's the max safe boost for 94 octane on say a 2012 pro? Anybody offer low compression domes? If not, can I machine my factory ones? increase the squish area or??? I don't need anything billet or fancy, just would like to run pump gas if possible overall, or depending on price what will 50/50 with av gas get me? 8#? Thanks.[/]
Dependent on...
1) Elevation. 94 will push 7psi at 10,000 feet no problem. Much less at sea level
2) Timing. How much timing was pulled from the map? If you pull gobs of timing, you can end up pushing pretty big boost numbers on pump gas (ish)
3) Charge Temps. If charge temps are on the higher end of "acceptable" you'll want to keep your boost in check, all other things considered, on pump gas.
So long story short, the answer to your question is "depends!".
