C
chevy_man
Same problem SLP has had forever ?? getting things to run right with twin pipes.
I'm wondering if the stock setup scavenging from both cylinders creates stability.
I just think it creates a broader powerband.I'm wondering if the stock setup scavenging from both cylinders creates stability.
Rode with a guy who had twins when they first came out and thought they sounded horrible. But he said the sled pulled harder.Nope, thats a good enough reason, its YOUR sled, I was just curious. They do sound killer… even though they are loud.
SLP has been working hard on the tune for these. Last week I downloaded the latest revision, think it was number 3. Had a chance to run it in some pretty deep powder at Wolf Creek. The new tune is light years better that what was originally released with the pipes, and yes I do believe the new 22 ECU was the main source for the issues. I have to give the people at SLP kudos for their work on this, once they were aware of the problems they worked diligently to resolve, I even received a call well after business hours from Jerry (SLP manager) to discuss the problems and his options to help resolve. I think there is still a little left on the table but overall the sled runs well. I did do some of the extra things, added the TRS recommended bung higher up on the pipe, and I heat wrapped these (total PIA). One thing that for sure will help is better air intake options when in deep powder, the stock vents clog up quickly in deep powder, more venting options are hopefully in the works.Is it the new ecu system of the matryx that is throwing slp for a loop? Or same problem they had with the axys 850?
Stock head on mine. I Have not added extra base gasket.Is everyone running them with the SLP head or could running with the stock head reduce compression similar to the extra base gasket??
There are plenty of used sets for sale for cheap. I would stay away if you are riding in WA. I haven't seen a set run as advertised.It looks like this discussion ended. Am I correct to assume everyone got most of the issues worked out and are happy now?
I am thinking about picking up a set of twins and am trying to decide if it's worth it. I ride generally around 4-6k in WA but will also be making multiple trips to higher elevations. It seems that staying away from the head might be easier to deal with as far as tuning. Did SLP work out the tune now so that I can get away without doing the extra modifications that Tony suggested? I am hoping to be able to basically bolt some parts on and change weights when needed. Did they get dialed to that point yet or should I stay away? I am fully aware there are a lot of people who have had bad experiences with the twins but am hoping things may have changed.
Any advice other than buy a Boost would be appreciated. My boost belongs at the bottom of a lake!
Sorry to hear this! Hope you heal up quicklySLP has another tune. Installed it last week. Runs amazing the mid range will literally pull your arms out of your socket. Can't wait to put a set on my 9r when it gets here. Ya the tunes sucked at first but each one is better and better. They have the 850 figured out!
huh?Sorry to hear this! Hope you heal up quickly
You said your sled “literally pulled your arms out of the sockets”huh?
Total freaking nightmare. That SLP is still selling this set up is criminal. I wasted a season and a half trying to get the set up on my sled to run without the death bog, fouling plugs at least every other ride, going into a weird limp mode or even running clean and as advertised for one complete day of riding. The staff at SLP was alway available, always had things to check and fix and adjust but the sled ran like crap from day one to the day I took that garbage off and returned to stock. Now they are advertising it for the Matryx. Again is such a shady thing to do to the sledding community. BTW, my kit was installed professionally, was worked on and tried to get it running right by professionals, every single thing SLP said to do check or change was done checked or changed and again I never got one single day of trouble free riding. The WORST thing was that the half days it ran well the sled made awesome power, the mid range was really strong and the top end just kept building to 8600-8700 rpm. That power was really hard to give up and why I tried for such a long time to get it running well.
If anyone wants to stick their head in this oven I have the kit I took off my sled, complete and in excellent condition for less than half price. $1500. It sucks, it is going to suck for you so enter this pit of hell well informed and prepared for the trial it is.
