Like many of you, I was thrilled when Polaris came out with the Series 9 3.25” track. From time to time, we need the extra traction a big paddle provides with the dry powder we have in Montana.
I installed it in my 2022 Matryx. I was disappointed that there was only about .375” clearance from the paddle tips to the front cooler.
Polaris’ recommendation for track tension is to hang a 10-pound weight from the track and adjust the tension so that you have .5” to .625” sag. I’ve long considered this to be too tight. Rolling resistance can be reduced a lot by adjusting the track tension so that the tops of the rubber drive lugs are even with the bottom of the hyfax. No additional weight is used in this case, only the weight of the track itself. One can run a track looser than this, but there isn’t a decrease in rolling resistance so there isn’t any reason to do so.
As I was setting up my sled, it became increasingly clear that the track would be hitting the front cooler under acceleration. The centrifugal force on the track going around the 6 tooth drivers at 40mph is 30 lbs. If you set the track tension to Polaris’ spec, you know that there is at least .5” of looseness in the system. That is with 10 pounds of force. Certainly, there will be times that the track comes off the drivers at least .5” with 30 pounds of centrifugal force acting on it. Remember, there is only .375” clearance at rest with this set up.
I rode my sled this way for the winter of 2023-24. Last spring I started working on a drop and roll. My sleds now have all the clearance that they need even with 7 tooth 3.5” pitch drivers which are over an inch larger in diameter. I can adjust the track tension to my liking and not worry about the track rubbing on the front cooler.
We will be making a limited run on the parts needed for you to drop and roll your own sled. If you have questions, or would like to order, give us a call.
Andy
4062614618
