O
Here is a link that you can read all kinds of information about global warming/cooling.
Myths, facts, who is doing what and why, loads of great links.
http://www.isthereglobalcooling.com/
Ollie,
A while back I was reading a study linked to another link you posted. I believe it was a NASA study that indicated ice core samples showed that the CO2 levels during the peak of the last ice age where like 4000 PPM more than 10 times what we have today. I may be wrong but I dont think that was caused by man either. It sure would be nice if people where smart enough to see the obvious flaws in the global warming logic.But then If that where the case most of what is dicussed in this section would be unnecessary and the world would be a much better place.
Actually, there is very serious evidence that Co2 does have a direct coelation between warming and higher Co2.
However, it is a byproduct, not the cause.
Reasoning behind this is simple when you think about it.
take a piece of meat, toss it in the freezer.
It doesn't decay very fast does it.
Now leave that same piece out side when it is 80 for a couple days.
Decays pretty fast.
Decaying things give off Co2.
So, when it is warmer things decay faster and give off more Co2.
Plant matter, bodily waste, etc, all decay. All that gives off Co2.
Problem with that theory is animals and plants had to sink the CO2 in order to grow, and die, and then emit them during the decay process, as CO2 or CH4.
They were talking about 10X increase in concentration. I do believe that at that level of increase would raise temperatures some. Not as much as Al Gore believes, but some.
When the earth gets cold, the little critters in the oceans (phytoplankton and such) stop growing. Their the source of all the Limestone, with is calcium carbonate, they don't decay as much as freeze in stone, the CO2. The source of CO2 then, is natural leakage, and volcanoes. CO2 builds up, and you get some low altitude warming from that.
CO2 is a product of warming, it doesn't create warming. Scientific evidence clearly shows there is no greenhouse effect associated with the warming we experienced in the 90's. Atmospheric temps are not increasing at a rate higher than surface temps, which is a greenhouse characteristic. What heats up our plant during the day? The sun. It couldn't be more logical or obvious that solar cycles are what impact the earth temps. Watch the movie or read some data on the site referenced below. They had a great analogy on there. The engine in your car is what powers it, much like the sun powers our planet. When your car won't run, do you investigate the engine or do you go look at something insignificant like a lug nut (CO2)? CO2 is a trace gas, it is basically insignificant in the makeup of our atmosphere, much a like single lug nut on your car. Even a 1st grader could completely understand this analogy and understand that blaming CO2 makes no sense.
But, with all that said, CO2 does make a small contribution to temperature. It might be 10% to 30%, but it's a contributor.
The major point to consider is, does it make any real difference, and what would be required to reverse that 10%? The changes would be mind blowing. Basically, you'd have to kill nearly all humans.
Don't forget, we are due for an ice age, that 10% might help save a some people. Global warming is nothing, in the face of global cooling. Global Cooling is a potential civilization ender. Global warming is inconvenient at best.
For the last 11 years we have not observed any increase in global temperatures.
And our climate models did not forecast it, even though man-made carbon dioxide, the gas thought to be responsible for warming our planet, has continued to rise.
