Making Tracks
sw Pub
... a very interesting email RAILROAD TRACKS
The US standard railroad gauge (distance between the rails) is 4 feet,
8.5 inches. That's an exceedingly odd number.
Why was that gauge used?
Because that's the way they built them in England and English expatriates
designed the US railroads.
Why did the English build them like that?
Because the first rail lines were built by the same people who built the
pre-railroad tramways and that's the gauge they used.
Why did 'they' use that gauge then?
Because the people who built the tramways used the same jigs and tools that
they had used for building wagons, which used that wheel spacing.
Why did the wagons have that particular odd wheel spacing?
Well, if they tried to use any other spacing, the wagon wheels would break
on some of the old, long distance roads in England, because that's the
spacing of the wheel ruts.
So who built those old rutted roads?
Imperial Rome built the first long distance roads in Europe (including
England ) for their legions. Those roads have been used ever since.
And the ruts in the roads?
Roman war chariots formed the initial ruts, which everyone else had to match
for fear of destroying their wagon wheels.
Since the chariots were made for Imperial Rome, they were all alike in the
matter of wheel spacing. Therefore the United States standard railroad gauge
of 4 feet, 8.5 inches is derived from the original specifications for an
Imperial Roman war chariot. Bureaucracies live forever.
The next time you are handed a specification/procedure/process and wonder
'What horse's *** came up with this?', you may be exactly right.
Imperial Roman army chariots were made just wide enough to accommodate the
rear ends of two war horses. (Two horses' butts.)
Now - the twist to the story:
A Space Shuttle sitting on its launch pad has two big booster rockets
attached to the sides of the main fuel tank. These are solid rocket
boosters, or SRBs. The SRBs are made by Thiokol at a factory in Utah.
Engineers who designed the SRBs would have preferred to make them a bit
fatter, but the SRBs had to be shipped by train from the factory to the
launch site. The railroad line from the factory happens to run through a
tunnel in the mountains, and the SRBs had to fit through that tunnel.
The tunnel is slightly wider than the railroad track, and the railroad
track, as you now know, is about as wide as two horses' behinds.
So, a major Space Shuttle design feature of what is arguably the world's
most advanced transportation system, was determined over two thousand years
ago by the width of a horse's ***!
And you thought being a horse's *** wasn't important!
Ancient horse's asses control almost everything.
CURRENT Horses Asses in Washington are controlling everything else.
  • Like
Reactions: KSH
