this is on a 11 pro with a silber turbo and running av gas. its been running great all winter long. then i had a fuel leak and ran it out of fuel, ever since then the mag side is running lean at idle and cruise. the afr would read 16 and the egt would be 100-200 degrees hotter on the one cylinder. at wot the readings are normal. i checked the plugs at cruise and the mag side plug was running alot leaner than the pto side. i checked for leaks with starting fluid, no change in readings or idle. i pressurized the system and found no leaks. this is my first fuel injected sled, so i have no idea. is the one injector bad/dirty? fuel filter plugged? throttle plates out of sync? with the green mode on 8 it would idle and cruise around 15. any help is appreciated. thanks
