Ordered 3/10/2011 (Thur), arrived 3/14/2011 (Mon).
Thanks Matt (madsigntist)!
Great fit, the bolts fit tight in the holes, no slop/play.
Good instructions. One note of clarity; the teflon washers [I assume] go between the guage plate and base plate.
Install time was 1-1.5 hour for me (after removing the hood, and getting it inside on the table). But I took some pics along the way.
I did remove the windshield/headlight, and highly suggest you do so for the install, much easier to deal with wires, drill holes, and install nuts.
Those plastic grommets on the w/s trim were a pita..
Also as mentioned in the instructions, dealing w/ the rubber grommet around the gauge is prob. the most annoying part. I got it wet, and it seemed to help..but it was still a hassle. It came out easier than it went in, oddly enough...or maybe not?
PB Album Link
Holes Drilled
Base Plate Attached Under-Side
Base Plate Attached Top-Side
Guage Attached Back-Side
Guage Shot From Front
Guage Shot From Side
Guage Shot From Riding Position
PB Album Link
Holes Drilled
