Machine died and won't start, 14 pro.
2014 pro, 400km on it. Just got back from vale, I sprayed it off lightly at the car wash, went to unload it from the truck, as it was idling to warm up it just died.
I tried to start it again and nothing. Checked tether, kill switch, tried and tried, nothing. I unplugged the tether, tried again nothing. Pulled a plug and checked for spark, no spark.
I went in the house, swearing of course, came back out after 10 mins, tried to again and it fired up.
Anyone have any ideas what I can check? It's never done this before and always starts easily. If this thing leaves me stranded on the mountain, I won't be a happy camper.
I have a 2014 800 and 600 Pro. Both have Polaris tethers and BOTH had issues cutting out and not starting. It turned out that the tether was the issue. I unplugged it and it ran perfect. I believe there has been some issues with the Polaris tether this year. They are replacing both of them.
It sounds like you have already tried unplugging the tether. However, your issue sounds electrical to me. Remove a spark plug, put it in the cap, set the tip on metal and have someone pull the cord. See if you are getting spark. That will tell you if it is an electrical problem.
I checked for spark, there was nothing.
It is an electrical problem. I just have no clue what to even look for.
I unplugged the tether, that didn't help.
Anyone else have this issue?
assuming pull start, not electric start right? just curious. obviously you got water in one of the connections while washing, just want to make sure its not electric start before i offer any assumptions.
I would guess water in the aux shut off (kill) switch on handlebar. Water got in there and completed the circuit-- killing spark to the motor.
When it dried out, no more problem.
I'm gonna guess water in the kill switch as well.....but that's kind of scary being a SNOWmobile and all....
It is pull start.
I was spraying the riser bag off, so maybe the kill switch, but like a guy above said, this is a snowmobile, you'd think the kill switch would be water proof??
Even 'waterproof' stuff can get water forced into it. My Yamaha ATV owner's manual says specifically in it not to use a pressure washer from the car wash to spray off the CV joints because that can force water into the case. My bet is you hit something just right to push water into the connection. There's a lot of force behind that water. (And yes I still spray the CV joints at the car wash - but I am a little more careful than I used to be)
^ there we go I am not alone. There must be something water is getting into.
I didn't spray it close and hard either, it was more of a misting off.
To the fellow above that had this issue, have you had any issues like this when sledding?
Had this exact thing happen to me Sunday. Washed off the 600, and she wouldn't fire up to get off the trailer.
Drug it into the storage unit, came back yesterday, fired first pull.
My guess is I hosed the kill switch down. Sprayed some WD-40 in the housing of kill switch and key switch, and shazam, away we went..
Doesn't happen on the mountain much because the snow doesn't run into the switch at 1500 psi like car wash spray is my guess :)
Ok I feel better now. Must be that kill switch. It has an opening where the wires go in, water probably gets in through there. Next time I'll try some wd40 or compressed air.
I killed an engine ECU on a '10 M by just garden hosing it off.
Had 5000 miles of in snow use. Was going to dust it off to be spick and span cause I was picking up the new '11.
Fired it up and ran it out onto the driveway. Misted it with some cleaner and hosed it off. Only got pops when trying to restart. Disconnected and blew out all connectors. Still only pops.
Drug it onto truck, dropped it off and loaded new '11 and told them the story.
Week later I was told they needed to install a computer to get it to run again. Ouch.
Weird eh.
Pressure washers and compressed air are a no-no! They both will force water where its not supposed to be. The electronics on motorsport toys just cant take it. So if you use em, be careful!
