I had the same problem with my TM-6. Someone helped me here with good advice so I will pass it on. If you shut off the motor before it idles down low, it can be a bit dry in the cyclinders and is hard to start. If you add a 10K ohm resistor into the yellow temperature sensor wire, it will make the ECU think the motor is cold and will increase the fuel delivery (like choke on carb sleds). This gets it running right away. There is a hole in the bracket that holds the oil tank and a panel mount toggle switch fits perfectly into it. The hard part is getting down to the sensor wiring which is located at the back of the motor on the right side. The wires run in the velcro covered wiring harness.
If you simply open the wiring by unplugging the sensor, it will work but the 10 k ohm is usually enough to stop any error codes from poping up. Simply make a series connection in the yellow wire up to the switch and solder the resistor accross the switch. When closed, the circuit is normal and when open the resistor is in the circuit.
If you get the error code on your gauge, sometimes it is hard to clear even if you plug the sensor back in. Before the resistor, I had to fiddle for 20 minutes with the engine running pig rich. I finally unplugged the other temperature sensor by the ECU to give it another problem and sure enough it gave up on the first error. After replugging everything back in all cleared. I have used this method a couple times.
