M
I could use some help here in getting some ideas as to what is wrong with my 2007 M8 with about 2000 miles.
The sled dies out once it has warmed up after ride it a bit hard or after about 15 seconds of a wide open pull. usually it does it when I let off a bit on the throttle and then it will sputter out like it out of fuel. Once in a while I can save it for dieing completely. It fires up up first pull every time after. I've looked twice for wires that have shorted including under the fuel tank, disconnected every electrical item i could isolate to try to find it. The dealer here said timing sensor and they changed one, I tryed changing the other. tested out the water temp sensor, EGT sensor, and stator. Whats left? ECU, trottle runaway switch, and ignition coils? Any suggestions or ideas would be helpfull as I feel like lighting it on fire and sending it on it way right about now.
Thanks
Thanks
