07/m8 is 6.39 to 1
Arctic Cat Engine
Specifications
* F-Series/Crossfire
** M-Series
ITEM 370 cc 500 cc 570 cc 600 cc 800 cc 1000 cc
Engine Model Number AA37A9 AX50L6 AA56A6 AJ60L4 AB80L1 AB10L1
Compression Ratio 6.30:1 6.38:1 6.41:1 6.46:1 6.39:1 6.41:1
i have 13:1 on my corssfire /shrug minnesota/wisc/MI/ND
i run the 13 to 1 head at 2300 ft...with 91 octane...i am told that its safe...it never activated my det sensor running it regular 91 but for safe guard i just started adding two gallons of 111 race fuel with 8 gallons 91 octane...the 13 to 1 i think is considered a low elevation application..?? mine is Terra -Alps..
91 octane ,, elevation 300-1200.
plugs are fine ,
sounds like you need a fuel controller
I run 98 oct, and my plugs are almost white. How`s the colour of your plugs, when you were running only 91 oct?
Going to check plugs at 1500ft within a few days. If white, the head goes off and will be replaced by the stock one!
Race fuel will burn almost white. How is your wash?
i got a crossfire 800 and i have it stock and it is two stroke. i live on the coast of alaska and the settings are for 0 to 5000 feet. i rode it at 6500 and it was just fine if you ask me, but i was pretty high up thereWhat is safe to run on a two stroke at sea level???? 2000???? 4000?????ect.
my plugs are fine...but there is a lean spot 5500 rpm to 6700 rpm (30-40 mph)that if you stay in that area runs dangerously lean even with a box...if you richen it in that area then you have low end bog..so i just throttle through this range...im going to get my box remapped so that it doesn;t affect the fuel supply untill 4900 rpm so i can adjust the lean area and not have low end bog...i don;t need extra fuel in the low end...
