H
Hangtime
New member
07 M8 All Stock . Have a friend with same sled, so have been swapping parts . From idle to half throttle all is fine. The upper half is another story , studders real bad and lack of power.
Here's what we've checked or swapped
ECU
CCU
Power valves, clean & Tested
Fuel pump
Checked injector screens
Tested TPS
Exhaust sensor
Looked at stator , may swap this next.
Checked out air box .
Tested coolant sensor - seems normal
swapped knock sensor
I should have just swapped his Hood ! Where should I look next ??!
Hangtime
ECU
CCU
Fuel pump
Tested TPS
Exhaust sensor
Hangtime
