T
tkuss
Here's the deal. I have a 2010 M8. Roughly 3000 miles on the chassis, brand new engine as of this year.
I am not able to get this thing to hold r's in powder or anytime the track trenches. I am hitting about 8100 rpm on the trails all day, runs great on the trail. Off trail I would say I am at 7000 rpm 80% of the time, at times it will jump up to mid 7's if I keep her pointed straight on a flat meadow, and ive seen it drop to as low as 6500 in steep climbs when under alot of load.
Other details - I run mds weights (61.9 grams roughly is what steve has shaved them down too) I Have been having problems with the clutching since I bought it. I run a blue pink SLP primary spring ) per recommendation of steve at mds. I run a speedwerx spring in my secondary at the moment. I forget the spring rate/color of it, but I know I have spoke with speedwerx on the phone and they say this spring has the same spring rate as the stock orange AC secondary spring. I live in CO and ride do 95% of my riding from 10,000 to 11,500 feet. I believe my motor mounts are in decent shape, while not brand new, I saw them when replacing the engine this summer and those should not be the problem.
Last year I had this same problem, I sent my secondary into Racin Station and they replaced the fixed sheave secondary bushing. After that the sled would hit 8000 rpms on the steepest of climbs. I would also note that after this, I believe my clutch would not fully shift out on the trail, as I could barely get above 45 mph with the stock gearing and clutching.
Right after the bushing was replaced, I would have consistent problems with my secondary not fully closing. I would come to a complete stop and my secondary would still be open a bit. I managed like this for the rest of the season. Over summer I told racin station about the problem and they re-replaced the bushing free of charge as they inspected it and found it to be warped.
Now it is this year, and the sled is doing the same thing, but even worse. If I go into a carve On a flat meadow, my sled will only reach 7,000 rpm pinned.
Help me get this thing figured out and clutched right! I am not super picky when it comes to my sled running perfect, but this is unacceptable. Please give me your opionion, or solution if you have had a similar problem.
Sorry for the long writeup, just wanted to make sure I answered any basic question most would have
Thanks
Thanks
