A
I have a 2005 M6 that has a D&D m8 kit in it with a D&D single pipe and D&D can. Timbersled intake. Boondocker box. supreme tool rave style exhaust valves to eliminate that problem. It is a really great sled when it runs but last winter i couldnt figure out what was causing my problem. I have good compression on the both pistons. replaced the throttle bushing.Here is the problem:
Sled runs very strong and normal up until 6500rpm where it bogs. When it bogs, the EGT shows the PTO cylinder losing all temperature and going back to 700-900degrees or lower while the MAG side cylinder is reading the normal temp of 1200-1250 degrees. Once in a while it seems if i let the sled cool down(5-10mins) i get full power for a short burst of 10 to 45seconds or until i hit a bump or something that puts an additional load on the eingine and then back to the bog of 6500rpm . When it runs for a brief couple seconds it runs like a raped ape with both egts reading normal temps. so that makes me think that it is not a clutch problem. plus if you put the sled in the garage and runs adn shifts it up it runs up fine. i have checked the barometric pressure sensor coming from the efi box and it is free and unrestricted. The air temp sensor is mounted in the timbersled intake and was not an issue in the stock intake or the timbersled intake because the problem had not changed. I rode the sled all last season like this with the intermittent burst of power but 99% i was limited to 6500rpm. I still managed to put 800mi on it last year and tow various skiers around the alaska backcountry. This fall i want to get this thing fixed!
Here is what i have come up with:
engine is obviously cutting out on the PTO cylinder at 6500rpms in someway causing me to lose egt temperature to about 700-900degrees. after reading through the forums for help this is what i am thinking.
stator failing - cant supply enough spark energy but why would it go for so long and not completely fail?
Corroded injector wire- not able to keep spark energy at high rpms
Coolant bottle cap cap has typical sealing issues - but why the intermittent power just to tease me?
Faulty injector seems like its in the area and could cause a problem like this.
Bad efi box i hope it is not this, and why would it run once in a while at full power?
I will also try to emulate the problem in the garage where it appears to run fine. ( no load) I will be trying the coolant tank replacement to see if that gets me better results first since it is the cheapest and easiest to fix at the time. Any help would be greatly appreciated. I just wanna keep her pinned at 7800rpm because that feels so damn good!
