U
The sled is a 09 m8 full race setup
I am running 9 lbs on 100ll
fuel psi 41lbs
green 4
yellow 3
red 0
green/blue 5
red/blue 7.5
afr 11.8-12.0
9000-11000 feet
My questions are, first it seams a little boggy on bottom end. I am wondering what numbers others are running also should I be running 100% 100ll
Has anyone else seen this problem. The first and second ride out everything ran unbelievable third ride out all day was great until the way back to the trailer sled bogged and almost died. I noticed the blue light on the attitude box was on solid like i was always in the turbo setting and I had to limp back to the truck. Got home pulled it off the trailer and everything was fine. Got it in the garage and dried it out talked to shain and he said that it was moisture in the sensor, dry it out it should be fine. dried it out and fired it up again everything ran perfect. So we went out again and it ran well for about an hour then same thing. the part that has me concerned is that it happened at the exact same spot as last time which happens to be at the lowest elevation we ever get. needless to say i talked to shain again and he swapped me out boxes and says that he has seen it before but it is very rare
also are you guys mounting the attitude box somewhere other than on the bars to keep it out of the conditions
sorry for the long post and thanks Hatchers for all your help Troy
![12-11-10 042.jpg 12-11-10 042.jpg](https://www.snowest.com/forum/data/attachments/101/101163-4344952df1082a1dfdc0b0157ea95e55.jpg?hash=Q0SVLfEIKh)
fuel psi 41lbs
green 4
yellow 3
red 0
green/blue 5
red/blue 7.5
afr 11.8-12.0
9000-11000 feet
