m7 with oil delete. What ratio to mix?
JordanWilliams
New member
I have an 06 M7 will an oil delete kit. The guy who had it was mixing 32:1. Runs great. He said on warm days it had a little bit of a low end bog. What is everyone else mixing. 40:1 is going to be a little leaner but will it be enough for WOT? I have a dual read KOSO Pyrometer. I am also familiar with ratios as I ride 2 stroke dirtbikes. Thanks!
good oil and 50:1, When I had my turbo m7 I ran Klotz mixed 50:1 and never had a single issue.
EGT arent going to tell you if you have to much or little of oil FYI.
Im planning on running amsoil dominator. Cleanest burning premix oil I have found. Doesnt load up near as easily and on my Dirtbike with 100 hours I have yet to clean the power valves. Amsoil recommends mixing 50:1 for all applications of Dominator. I run 32:1 in my dirtbike for the safety feeling. I know the EGT wont tell me if im getting enought oil but if it is getting less its going to burn hotter so it will show a difference from 32:1 to 50:1...
