M7 overfuelling?
R
Rudy198
i have this darn problem with my 06 m7 we swapped injectors,new coil,and it's always on the clutch side that the plug stays wet.Can't get anymore than 75kph on hard pack.Is it possible that's overfuelling and if so is that controlled from the ecu?Or can it be adjust manual.Need some help getting really peeved about this thing,Thanks
we took the side that was having trouble out,looked at never noticed anything unsual about itwiped it off a clean it,replaced it and did the same thing.
Did u check the cable adjustment, make sure its opening? When its supposed to. If the power valve doesnt open that cylinder will just load up.
You might try replacing the fuel pressure regulator. It is connected to the fuel pump which is inside of the fuel tank ( why it has such a large opening). I was having very similar issues last year and tried this is what the problem was.
