You have to pull the fuel pump and look at it. I made a housing that looks like the bikeman or ovs, out of aluminum. Threaded a bolt and a lock-nut into the end, just like the bikeman and ovs. Cut the end off the pressure regulator canister, just like the bikeman/ovs, and installed the pressure regulator, with spring, into my housing, which is held on by the bolts that hold the regulator assembly on the unmodified regulator, just like the bikeman/ovs. Re-install the whole assembly in the tank. Then just set your fuel pressure to whatever you want it to be (you can connect the fuel pump to 12v. and set it close before starting the sled). Make sure you don't have a lot of fuel in the tank.
Disclaimer...mod your fuel system at your own peril! The stock fuel line and clamps are junk...replace them with high quality high pressure line and real clamps. Setting your pressure is critical to avoiding burndowns...doesn't take too much too low to be too lean! I highly recomend EGT's.
