All parts from 2006 700 crossfire. May have other parts not listed.
leigh76@yahoo.com Engine parts have 1200 miles on them.
cylinders $200 each sold
pistons $30 each sold
stock 700 head $100 sold
power valve w/ assembly $150
power valve cables $40
Throttle body's triangle with injectors and sensor $275
servo motor $125
ECU triangle $375
Flywheel $200
2* timing key $15 shipped
Air box stock intake $40
main wiring harness $125
temp sensor $40
Coolant sensor $40
Ignition timing sensor $60
voltage regulator $40
coolant hoses $5 each
stock pipe w/ cover $SOLD
stock silencer $50
primary clutch fixed pin $150
stock intake $10
speedo $150
oil pump $100
reeds $40
Digatron DT52SL EGT $200
recoil $SOLD
belt guard $35
Other misc. parts and bolts
servo motor $125
ECU triangle $375
Flywheel $200
temp sensor $40
Coolant sensor $40
stock silencer $50
stock intake $10
speedo $150
oil pump $100
reeds $40
recoil $SOLD
belt guard $35
