R
rigrat
Good day. Hit a tree last season with my m7 which caused damage to my sleds hood, nose piece and other plastic plus the airbox was smashed.When the accident happened i was able to remove loose pieces and ride sled back to my pickup. The problem is that the sled started dropping a cylinder part of the time (may have inhaled some pine needles) into motor. I replaced all broken pieces and cleaned everything up. Took it for a rip down the ditch yesterday and found it was still dropping a cylinder. Sled seems to run ok at idle and part throttle but when opening it up to full throttle it will drop a cylinder everytime. It may not drop the cylinder instantly but will drop it very soon after WOT. If i go back to part throttle it will run on both cylinders again. Checked the compression and found both cylinders were within 5 lbs. One plug looked like it may have been fouling so i replaced it. No difference. If it was ignition it would probably run on one cylinder all the time, correct? Could it have a broken reed and would a broken reed cause it to act this way? Dealership mentioned unhooking kill switch, which i tried with no luck. Someone else mentioned checking ecu for code. How do i check for codes??Appreciate any and all help! Thanks in advance.
