m7 boondocker control box problem
Jonathanpitzl
I have an 05 m7 with a boondocker control box, when I start the sled the control box says problem is mag side injector. and it pops up every 5 seconds or so, so I cant make any changes. any help or ideas would be hutch apprcialed
I would wager that the ground wire is broken or is not grounded properly. If it is getting a true mag injector error and the ground is hooked up correctly it will still run. Follow the black ground wire from the control box to the chassis where it is grounded and make sure there are no breaks, frays, or pinches in the wire.
Check the wiring to the mag side injector. Look for the same issues described by RS. I have seen that exact issue two times and both times it was one of the wires on the mag injector.
