Ski-Laxn
Ok before you tell me to search I Did.
Sled 05 153 with a Vohk 866 topend, BMP pipe, y pipe, boondocker box, egts, and a koso af gauge that works when it wants. Still fine tuning.
Clutch set up.
Primary 65g cutler adjustables, with slp Black yellow 120/310
Secondary 36* stock helix,BMP torsional with BMP black on second from end.
I need 8100 RPM.
can only get about 7600-7700 occasionally it will go higher. My question is do I need heavy weights for the SLP spring?
Should I change to a 300 finish rate?
Clutch set up.
I need 8100 RPM.
