Trying to help a friend set up a M7 he just purchased from out in SLC. It now resides in CO. Need to set it up for 9,000-12,000 ft. Boost can be adjusted. Probably will run most of the time in the 7-10 lbs. of boost range.
I know my way around the Boondocker box as I run one on my NA M1000 but there are settings I'm not familiar with.
I'm familiar with the different RPM ranges and the LO-MID-HI and trim settings. In the 3000 map it has a N2 and DL setting. What are these?
Below are the current settings: Any help would be appreciated.
3000 LO 04, MID 01, N2 01, DL 01
5000 LO 05, MID 05, HI 05, TR 0
6700 LO 03, MID 04, HI 03, TR -02
7800 LO 06, MID 07, HI 05, TR 03
8600 LO 03, MID 03, HI 13, TR 02
(suggestions)
MAP 1 -04, 0, 03, 06
TURBO LO 2, 4, 6, 13
(suggestions)
MAP 1 9, 12, 15, 18
TURBO HI 90, 83, 66, 80
(suggestions)
I;m not clear as to what the bottom two maps are about. Are the turbo low and turbo hi settings PSI or fueling ?
Any info would be very appreciated.
Thank you everyone.
Quinton
I
(suggestions)
(suggestions)
MAP 1 9, 12, 15, 18
(suggestions)
Thank you everyone.
Quinton
I
