m6/7 to 800 big bore, 200 miles, cat pistons...
m6/7 to 800 big bore, 200 miles, cat pistons, ecu, crank, wiring... complete!!!!
motor has 200 miles on it, running the stock 800 pistons. speedwerx high comp head (pump gas at elevation, mix down low), welded and trued crank.
complete motor, wiring harness, ECU, throttle bodies... you just need pipe and fuel controller.
$2500 complete... 2000 for just motor.
motor is in sled right now, selling because it wont work with the new turbo setup.
brock
big bore questions
Who's kit is it? Speedwerx, Racinstation, RKT, ...?
Have you ran it above 8,000'?
kit info
it was built by hanson racing.... its the same as everyone elses kit, stock cylinders punched out, running the stock cat pistons. porting and compression is great for high elevation. it has a speedwerx head at 13.5:1, perfect for pump gas at elevation.
motor runs great, i just have a turbo going in this chassis and the turbo wont work on this motor. i could get it to work but why ruin a perfectly good setup so i'm going to sell it complete and most likely fit a 1000 in.
make me a reasonable offer... i have no use for it. its at dakota performance right now if you'd like to call jeff and ask him about it. i am a cat dealer also.
