M1100 Turbo Problem
J
jbunce
Just removed the plastic cover to check if all the hoses were properly connected been having issues where ill be loosing power and also seeing 25 psi on a stock sled minus having a can been doing it since day one and was finally given a tip on a line i have not check yet and this is what i found...
something to look at not sure if other people are having this issue but im sure im not the only one...
Likely could tap it out with a pipe tap and make a new fitting. But that would not be stock.
I guess I would expect a new compressor housing or new fitting. As is this came out the tolerance was not right or it took a good enough hit that it could fall out then the housing is likely stretched out.
Also JBounce glad I could help out.
