This is my first post on this site...see there are a lot of knowledgable folks on here, so with my first post heres one for you.
i just acquired my first cat, an 09 m1000 snopro and right from the get go I had them install a mbrp can on it. i only have 70 miles on it and am noticing a bog 4 times out 5 when I punch it.
i had it back to the dealer and they adjusted the belt deflection and did the first time in service.
I was hoping to see the bog gone, but it is still there. i read somewhere here on this site that certain cans may cause this bog...is this correct? Also it seems to be worse as the machine heats up.When cold it is not near as bad, or if you let it sit a while and allow it to cool,when punched it rips, once good and warm it'll bog. I need to put a smile on my face!!
Has anyone had this sympton with the mbrp or any other can? I will be putting the stock silencer back on to try and rule out the can issue. I'm hoping to be able to still use a lightweight can for weight savings though.
Thanks
Thanks
