Hey all,
I have a 2009 M1000 Sno Pro. A couple weeks ago the engine went down while hill climbing. It is my first sled and has been decent to date. I have been enjoying learning the mechanics with this sled and would like to do as much of the repair work as possible myself. I also know there are tips or techniques that make things easier that more experienced people would have. I also am interested in what may have caused the failure and all things that I should check out or fix while things are torn apart.
Current Setup:
M1000
1,980 miles
Full SLP Exhaust
PCV Controller
Timbersled air intake. (Installed last year)
BDX Diamond Drive - M8 Gearing (Also installed last year)
I have pulled the exhaust and cracked the head enough to see that the clutch side piston is covered in shrapnel. I am assuming that I need to pull the engine out in order to really get into it much more? If I remove the engine what do I need to worry about to ensure that alignments are good when it goes back in?
Thanks in advance for all wisdom imparted!
Current Setup:
M1000
1,980 miles
Full SLP Exhaust
PCV Controller
