I put a lot of thought into this and it may not make sense as I tend to look at things differently than most, may have to read a couple times to put it together.
My 07 m1000 stock clutching worked much better than my 09 m1000 clutching and slp clutching, both sleds had slp pipe, the 07 would run 60mph track speed and on the flat would snap all the way to 95-97mph without a hiccup. the 09 might hit 50mph track speed and on the flat it snaps to 78-82mph and then slowly climbs and blows the belt. and at times it seems like off bottom it sling shots/ over engages the the clutching to far hits 7600 rpm and then binds and pulls the rpm down to 7200 and holds. It just so happens 78mph is when the clutching is at a 1:1 ratio, so each clutch has equal amount of surface area on the belt.
(the 07 had a for post which carried a lot more weight.)
this is what I found on the springs
on the parts list the 07 m1 uses a Y/W drive spring and a Orange driven
the 09 m1 comes with a purple and a orange. but also shows a option for the Y/W.
(Primary) the Y/W has a 122/285 rate(07) and the purple a 121/240 rate(09),
(Secondary) then the orange is a 175/280 rate.(both sled same)
Now it appears to me that with the purple spring and the required clutch weights to reach wanted rpm, it is not applying enough pressure to pull through the weight of the driven/orange spring (121/240 vs 175/285) causing the primary to slip and the secondary to bind. The 07 was 122/280 vs 175/285. I know the drive requires more tension to work and reduce slippage but it seems to be a ways off.
the 07 had a total of 272g of weight (68 each ) and the 09 225g(75g each)
so the 07 had 47g more to apply adequate pressure. any ideas on what would happen if I ran the same amount of weight on the 3 post and the Y/W primary spring.(or springs closer together in a sense, it would be a starting point) I know this is the route of my problem on the flat, as it quits working at a 1:1 ratio and the belts start to require different needs as it shifts into over drive. weather it be a softer driven spring or more force in the drive clutch. also the added weight might help slow down the sling shot effect enough to maintain rpm.
but I also want to run a 42/38 helix and a tension adjuster on the secondary and not sure how much it will change my needs.
parts list
07 M1000 4 post
SKU: 0646-229
Spring, Drive Clutch - Yellow/White
SKU: 0648-774
Spring, Driven Clutch - Orange
09 m1000
SKU: 0646-229
SKU: 0646-155
Spring, Drive Clutch - Purple
SKU: 0648-774
parts list
07 M1000 4 post
SKU: 0646-229
SKU: 0648-774
09 m1000
SKU: 0646-229
SKU: 0646-155
SKU: 0648-774
