M1 aftermarket performance updates?
E
Elevation
I just bought a used 09 M1 sno pro. I applicate your help on what I need to do to get the most out of the sled. I would like to work on it a little at time as I can afford it. it has rock rollers, been geared down to M8 gearing.
-I plan on sending the shocks to Holtz and have them do their magic, and add their middle shock spring kit.
-add air chambers (Nextech/Fett bros) to the fox shocks?
-lightweight can (not a loud one)to start with and add a pipe later. what brand?
-y pipe?
-vents & who's?
-intake?
thanks in advance for any other suggestions
Elevation
I ride an 07 so I'm not sure if this will matter and I'm not sure if the 09's stayed with the straight 36° helix but I swithched to a 40/36 progressive from SLP and it straight woke that baby up. I upgraded to the 3 tower clutch and had Racin Station in Driggs fit it with custom machined 77.5g weights (this is what their R&D decided was the best). I run an HPS can, which I believe is still the lightest on the market, it actually sounds stock at idle and low RPM's but when the powervalves open up it screams. SLP flowrites in the shock towers are a must, cover your nose intake screens with a bra or just buy a sheet of SLP prefilter fabric and make your own (this keeps any ice from building up under the nose which can cause cracks and breaks). Couldn't tell you about which brand of vents is best since I made my own with the filter fabric and a 1" drill bit. Whatever you go with have fun, you've got a great sled.
I may have an SLP can for you if you want... ill sell it cheap. Its mint and isnt loud at all. I would like a louder one thats the only reason i am selling.
the 09 respond well to the slp can.
the slp and SW pipes are the ones that seem to work the best at elevation. If you plan on porting it get the SW, rkt has a good port setup with that pipe.
I run the slp on an 09 and if I want more power i'll prob go with a turbo.
I also run a bdx intake, bd box, bdx oil delete( stock oiler sticks ). remove the snow flap its usless and get in the way.
I wouldn't do any power mods with egts.
slp is quiet, BDX intake.
BDX intake breathes well but makes noise and I wouldn't do it without a fuel controller just incase.
