There was a change to the sheave diameter from 10" on the 05/06 to 10.4". Not sure if that was in 2007 or not until 2009 when mechanical reverse went away. Not sure if the mechanical reverse models are built different than other years in general as I never owned one of those. 10.4" sheaves are considered an upgrade over the 10", but I recommend changing the belly pan if you do the conversion to get enough clearance under it. I did on my M7 anyway. 10" vs 10.4" also takes a different belt and alignment bar to set the offset. Tape measure should give you a quick check on diameter of what you have currently.
