M series fuel tanks...
snownman
479
70
I'm not sure what to do now, cat does not build a replacement fuel tank for M series sleds anymore. Does Anyone know where to get some uncracked fuel tanks ( I have 5 cracked necks} i don't care if it's M6,M8. M1000 . i can change the pumps etc. Just need good tanks... P.s. tried trailtank good luck.....Thank you
summ8rmk
Most handsome
12,369
6,043
yakima, wa.
Hot staple and Plastic weld the tanks. Cheap and easy if its just the common filler neck cracks.
Sent from my SM-G998U using Tapatalk
B
BradM8
Aug 4, 2012
100
34
Make sure to buy/build a brace to provide some support from the back and forth forces that is stressing the tank in the first place. I still can believe that cat thought it was acceptable to have the tank being the only thing to stop back and forth movement.
F
Jan 3, 2008
120
36
Hey BradM8 can you explain where the bracing needs to be done at? I am having a hard envisioning where a brace is needed.
J
jim
635
Boise
It's easy to repair yourself. I used filler from a HDPE plastic bottle (was a common cleaner spray bottle). Cut the plastic up into strips and applied with a soldering iron. Not hard...just make sure you are getting the plastics melted together...almost like laying a bead weld but much easier...just kinda d And mine was almost off the tank...only about an inch left holding it together. Works great now...no issue with anymore cracking or problems.
