I have the worst luck with fuel pumps. I have to replace my fuel pump almost every year. I had a 2005 M7 for five years and now own a 2007 M8 and both have had this same problem. I ran premix on the M7, but use the stock oil injection on the M8. I would blame alcohol in the gas except that this problem started for me years ago, before they even started adding ethanol to the gas in Utah. I never had this problem with my old 1998 Powder Special. Why would the M sleds be different??? No, it's not the screens or electrical; you can hook 12V right up to the pump and you can hear it trying to go but the shaft does not turn. You can switch polarity and try to spin it backwards or forwards, it makes no difference. In the sled or on the test bench, either way, the pump is frozen. I've never taken one apart, but it acts like corrosion on the bearings. I just bought a new one last February, and now it is bad 11 months later. In the past I've occasionally had them last even shorter times than that. Thank heaven for APEUSA.com or I'd be absolutely broke. Cat wants $450 for these stupid pumps, and APEUSA sells them for $115 (Walbro GSC 404). But it is still annoying to get up on the hill and try to start the engine and everyone has to go home because I've got no fuel pressure, then I have to order one and install it. Every year. Why does this not happen to everyone else? What am I doing wrong? Is there a way to extend the life of these pumps? Do you store your sleds full of gas or empty? Do you use a fuel conditioner before storage? One guy said take the pump out and fill it with mineral spirits in the summer. Seems a little ridiculous to me. I finally found a gas station that sells premium with no alcohol in it, but I'm not convinced that will make any difference... but I'll try anyway. Any other ideas?
