M series Diamond Drive gasket update
N
Nubulin
I just put the cat update gasket in my 07 DD. Will it stop the leaking? Has anyone seen an improvement? This POS has leaked since day one, I have had it apart a couple times to reseal and still leaks. My 05 had no problems.
Congrats cat on easily stripping aluminum threads! 13 time-sert steel thread inserts and problem solved!
Did you have to buy the kit or do they sell the gasket separately? I thought I seen something about spacers also?
Dealer didnt know about kit.
DD drool
Leaking cases on the DD have been an on going problem and all of mine have leaked. I though I was always being picked on by the cat gods each time I got a sled, then as I fooled with this problem and really got after fixing it , some cat and after market guys reafirmed what I always suspected:
1. problem start with case flex.......when you take the whole wirlygig apart and look at the setup, your secondary clutch is hanging out there on a pretty skinny thin little cover plate.........and it flex's. So, you look at what's going on and where you would need to have this thin outer case really fastened to the gear case body to be solid and you find a couple of skinny screws ( backside toward foot wells.)
2. So the bigger the motor, the longer the track, the better the clutching, the more agressive the rider, the harder the snow, the more likely you are going have flex'en and leaking. Loose screws are an obvious problem, then stripped screw are a real problem, and part of my fix has been bigger dia screw with heli coils installed and real tight.
3. the case flexing causes poor gear alignment when under extreme stress and wouldn'd you know it, gear case failure ???? SUPRISE SUPRISE
Knowing the cuase helps avoid a dismal future. If you weight 300 lbs, got the new stiff track and like to slam uphill drifts on your 1000 be cautious.
If you turbo'd the girl and slam uphill drifts pinned........you're good cause that track is spinning so hard it won't hook and hurt.
The cat cases are weak cheese, If I recall bdxtreme's replacement setup is better material ? Is that correct BDx steam ?
the kit comes with the spacers you need to install the gasket, and with new oil. The spacers are the same thickness as the gasket, they go behind each of the bearings on your two main gears. I think the kit is about $32.00 or so
I bought the seal kit from DB extreme -$15 and it didn't come with any spacers????? The input seal looked the same, but the output seal has two springs (inner and outer) vs the stock seal which only had a spring on the inside.
This is on an 08 M.
My kit came with
CASE gasket
2 spacers for input and transfer gears (to make up for the thickness of the gasket)
Oil
It was around $30. There is a kit for 07's and a kit for 08's. I will try to dig up the part numbers.
NOT to be confused with the replacement SEAL kit which is for the input and output shafts of the drive.
2602-191 2007 models
2602-267 2008 models
So RTV is not a good idea?? I just pulled mine apart and it had silicone from the factory. Also just put new seals in and it would suck to have to take them back out to put the spacers in.
The spacers go on the other end of each shaft from the shaft seals.
What??? Not following you there. So the dd now has a gasket to seal the case instead of using RTV? And where are these spacers supposed to go?
Thanks
