M-8 in tank fuel pump
ACTM7
Is there a fuel pump to install in tank to replace stock pump when installing turbo instead of adding aux pump that will provide enough fuel?
-whos kit are you installing?
-what year was is designed?
-I had two fuel pumps go out on in under 1200 miles...and im not a fan of the duel pump option as many peolpe had problems with it. The better option is to go with a High output pump similar to what twisted turbos is doing....im not sure who else is using a better fuel pump these days?
