M 1000 BD PG bog
I
ICM
New member
Numbers
3K 0 0 0
5K 0 0 0
PSI 4 14 33
Fuel Pressure 45lbs
110 race gas
7 to 8 lbs boost
9000 to 11,000 elevation
2010 sled
Bog out of the hole and in a climb if you get out of it and hit it again
any help would be great
Thanks
Numbers
3K 0 0 0
5K 0 0 0
PSI 4 14 33
Fuel Pressure 45lbs
110 race gas
7 to 8 lbs boost
2010 sled
Thanks
I would say judging by those numbers you're a little rich, my numbers look like this.
3K -03 -06
5K -04 -08
PSI 01 06 25
7 to 8 lbs of boost
6500 feet
What does your temps or A/F look like?
1300 top under boost
Shouldn't you have three number each
What year is your sled
My Numbers - little different
3K 00 00 00
5K 05 05 05
PSI 06 18 28
91 pump gas
5 to 6 lbs boost
9,000 to 11,000 elevation
2009 sled
EGT's - 1170 to 1200
