P
paramuir
Ok, so two seasons ago the oil line that goes to the lower casing (the brass pressed in fitting) popped out. Over the summer i used JB weld and put it back into place.
Tonight i went out for a ride filled up the oil and noticed it pouring out the belly pan, turns out after 2 seasons that oil line brass fitting has come out again,
so my question is who else out there has fixed this and how?? would a brace with a screw that can hold pressure on the brass fitting work? should i just try jb weld again (however my shop isnt heated so going to be hard to get it to cure properly)
thanks
thanks
