Hello,
I have an issue with the low oil level warning indicator light in the MFD on my '11 Pro RMK 800(163) - The indicator light is staying illuminated regardless of the oil level or input from oil level switch...........
- The switch is functioning properly(open when tank is full & closed when tank empty)
- No short to ground on the oil level input to ECU(violet wire)
According to the service manual the oil level indicator light is activated by the ECU & MFD via the CAN bus.............
Is this a programming issue that a dealer can take care of or is it more likely an internal fault in the MFD???
Thanks in advance,
Glen
Thanks in advance,
Glen
