I parted out my 2003 viper mtn and still have a ton of stuff left over. Here is a list of stuff I still have, its not all inclusive but it is close. Pictures of all parts can be seen here.
No reasonable offers refused. PM or post.
Air box
oil bottle
recoil assembly w/good rope
stator
stator rotor
Powervalves and cables
powervalve servo
coil pack
wiring harness
CDI
condensor/rectifier
Ignition with 1 key
footwell loops
trailing arm mounts
tunnel skid supports
fuel pump
carbs-complete
oil pump
motor mounts-full set
stock reeds w/cages (4 of them)
front heat exchanger
coolant bottle
coolant hoses
thermostat
stock exhaust pipe
stock exhaust can
slp exhaust can
jackshaft /w bearing
exhaust springs
headlight pod
exhaust deflector
handlebar mount
radius rod-belly pan bracket
belly pan plugs
spindles and steering arms
brake rotor
brake caliper and e brake
brake controls
choke cable
clutch bolt
steering parts
steering post
hyvo gears-21t and 40t
chaincase spacers
rail extensions 5" for 141 to 151, 144-154, etc. Might be more combos with big wheel kits. Fits with ANY pro action skid.
axle and jackshaft bearings
rear view mirror
water pump cover plate
mountain bar
Mountain machines 6" pivot bar riser
pro taper handlebars model CR Hi
Mountain max 141 skid parts-everything but rails
Air box
oil bottle
stator
stator rotor
powervalve servo
coil pack
wiring harness
CDI
condensor/rectifier
Ignition with 1 key
footwell loops
trailing arm mounts
fuel pump
carbs-complete
oil pump
coolant bottle
coolant hoses
thermostat
stock exhaust pipe
stock exhaust can
slp exhaust can
exhaust springs
headlight pod
exhaust deflector
handlebar mount
belly pan plugs
brake rotor
brake controls
choke cable
clutch bolt
steering parts
steering post
chaincase spacers
rear view mirror
mountain bar
