Lost all lights at once 97 ultra touring
I'm not sure if this would be it, but make sure your harness going up the hood is ok. I had something similar happen a couple years ago when my harness fell on the pipe and melted through. Lost all my lights. Also might wanna check your voltage regulator. The wires are an easy visual check. Good luck
Is the tach still working? It works off the same circuit as the lights so if it is working I would suspect the voltage regulator blew and took out all the lights.
I had my heated grips ground out on the bars and took out the stator. All the lights blew as well, that is how we caught it.
