Stuffed a Ski this winter and popped out the ski rubber..
When I went to put it back in the plastic around the ski bushing looked deformed and the bushing was loose..
I just pulled the ski’s to test fit the Rasmussen ski rubbers
And the bushings are now tight?
Hot garage fixed it?
FYI the SkiDoo rubbers are only safe if you run the ski in the centered position because the stock rubbers only have material in the middle of the ski, If you run them offset only a fraction of the rubber touches the spindle..
You guys probably already know this but if you don’t, set them to center or they will pop out! Not pretty!!
The Rasmussen rubbers contact the spindle all the way across the ski! Nice job! Then you can set the ski offset anyway you want!
My sled is a 2020.5 T maybe they changed the design for later years? I’d give it check!
