T
TheBreeze
I am looking for some tuning advise on my 2010 Boondocker RG kit. Overall fueling is working well, and the sled runs very crisp. The only real issue I have is the occassional stumble/loading up/burble when I quickly pin the throttle with very low ground speed, or from a stop. For example a quick throttle hit to lift the nose over a creek.
When applying throttle in that fashion it bogs out, wont spool up, and EGT's drop big time on the MAG cylinder. If i roll into the same situation with just a bit more ground speed, and slightly higher RPM's it gets right after it.
Is this something that people address with the off boost boondocker numbers, or should I be tuning in the Accel feature?
