We bought 2019 Evo's last year. I long tracked one last year with a 146 track and a pro suspension. I looked at the 2020 Evo Rmk and as Polaris stopped short of offering a true Rmk version and the one I long tracked was very close to what they are offering. The 2020 RMK in my opinion would more be described as an SKS. I decided to use some parts that I have acquired to long track the other one for a trip over Christmas.
My swap meet season netted me an Indy 550 144 rear skid, a 155 Pro Rmk skid, a 141 cobra 1.6" track, and some gripper skis. I did some measuring on my project sled 141 Pro Rmk on the rear axle placement with the 141" track tensioned and found that the Polaris Indy 550 144" rails could be used with a 141" track with some minor modifications. I decided to go with 7 tooth drivers to get some more room for the shorter track. The 7 tooth drivers did cause some issues in the end but more on that later.
![20191218_153954.jpg 20191218_153954.jpg](https://www.snowest.com/forum/data/attachments/281/281601-135567b6f770144bf8e6230d39b32c99.jpg)
Polaris Indy 550 144" rear skid. These come with 8.5" rear wheels. I believe the front and rear arms are the same as the Pro except the transfer rods on the rear shock.
![20191219_120414.jpg 20191219_120414.jpg](https://www.snowest.com/forum/data/attachments/281/281602-5b43dc126362aa5971e9ed3fe3ccefc7.jpg)
Cut out the rear axle slot and moved it forward as far as possible. It could go a little farther forward but some work on the axle adjuster would need some modifications.![20191219_120302.jpg 20191219_120302.jpg](https://www.snowest.com/forum/data/attachments/281/281603-115d3dde8724be64702afdd6e479851a.jpg)
Marked out the back of the rail and cut it off for some more clearance to deal with the wheels moved forward. Installed some new Hyfax and trimmed them to fit this cut.![20191218_154120.jpg 20191218_154120.jpg](https://www.snowest.com/forum/data/attachments/281/281604-d64309174a9b42b08fecfa6111d2afa3.jpg)
Pro Rmk arms and shocks.![20191219_192643.jpg 20191219_192643.jpg](https://www.snowest.com/forum/data/attachments/281/281605-ee1198d0f38400c6f277d7bcd047d44b.jpg)
Cleaned out all the pivot shafts and gave them some fresh grease. Assembled into the 144 rails with a new set of scratchers. Removed all the outboard idler wheels.
I took some measurements from a 2014 Pro Rmk for skid placement. I have attached a sketch. All measurements were taken from the drive shaft centerline and the top of the tunnel. The EVO 121 front arm mount was .125" farther back and .25" farther down than the Pro. As they were so close to where they need to be I went with the existing front arm hole in the EVO and made adjustments to the rear arm mount point to go along with the front arm placement in highlight. I have posted other Pro measurements in other posts and I believe these ones are the most accurate as I found some inconsistencies in my prior measurements.![20191218_154029.jpg 20191218_154029.jpg](https://www.snowest.com/forum/data/attachments/281/281607-1f614f7a4428462b4ca1eefcae73b0ce.jpg)
Found that Yamaha used 3" pitch drivers on a hex shaft. These will fit the Polaris hex shaft the Evo comes with. I wanted to keep the Polaris shaft intact so I used an Indy edge shaft and cut it shorter and machined the end to accept the spedo gear and turned the end to 1" to accept a locking collar type bearing.
I have attached a sketch for shortening and machining the edge shaft to fit the evo.![20191220_020632.jpg 20191220_020632.jpg](https://www.snowest.com/forum/data/attachments/281/281609-0dd4489404ee9e37ebe940f525d8a6bf.jpg)
The Evo front arm uses 7/16" bolts to attach to the tunnel. The Pro Rmk used M10 x 1.50 bolts. As the tunnel holes are too big some hat bushings were made to take up the space. Some longer bolts were also required due to the bushing thickness.![20191220_020647.jpg 20191220_020647.jpg](https://www.snowest.com/forum/data/attachments/281/281610-80b72fe59c81187f54a3309db9666365.jpg)
I had some Pro Rmk rear drop brackets for the rear arm mount. To get the arm the correct distance from the tunnel some spacer plates were needed. These were bolted on so they can easily be removed if wanted.![20191218_154157.jpg 20191218_154157.jpg](https://www.snowest.com/forum/data/attachments/281/281611-4a57600fb4f23132b385746a632945ab.jpg)
141 Cobra 1.6 Track.
Components were weighed as I went.
121 Evo Skid 58.4
141 Pro Skid 42.3
Pounds saved 16.1
Evo drive shaft 2.52 Pitch 7.4
Reworked drive shaft 3" pitch 7 tooth 7.0
Pounds saved .4
141 cobra 1.6 39.8
121 Evo track 31.9
Pounds gained 7.9
Gripper skis 12.2
Evo skis 11.0
Pounds gained 1.2
Rear arm mount brackets ( forgot to weigh) Pounds gained ?
Calculated weight saved on long track conversion is 7.4 pounds.
I weighed this sled before and after. This is a non electric start sled. Gas was drained out. Oil tank was filled. There was a spare belt and a rear seat storage bag installed on the sled.
Stock sled weighed 418.5
141 sled weighed 413.5
Weight saved 5 pounds
![20191220_120542.jpg 20191220_120542.jpg](https://www.snowest.com/forum/data/attachments/281/281612-f97f54942f8706d977871cac7403ae1d.jpg)
Rear snow flap looked to be close with the 141. It did get sucked up once while ridding but some reforming in the field took care of that and it did not get sucked in again.
![20191220_202752.jpg 20191220_202752.jpg](https://www.snowest.com/forum/data/attachments/281/281613-874a27dfe879d8d6bd85fc5735be4ee8.jpg)
Here is the o crap moment. Got it all done and was going to adjust the track and found it to be very hard to turn. After some looking I realized the 7 tooth drivers are not large enough to let the track clear the bump out in the chain case and the track was dragging on it. I then remembered reading about this long ago when the Pro first came out and guys were trying to install larger lug tracks. They were removing the chain case and cutting it and rewelding it with more clearance. There is enough room to put 8 tooth drivers in but a new track will have next to no room for adjustment and will be difficult to install. I finished this the same day we were leaving and did not have time to build an 8 tooth drive shaft so I took the quickest fix I could think of and just trimmed about 3/8" off the side of the track. Not the best solution but it did not delay our trip.
121 Evo Skid 58.4
141 Pro Skid 42.3
Pounds saved 16.1
Pounds saved .4
141 cobra 1.6 39.8
121 Evo track 31.9
Pounds gained 7.9
Gripper skis 12.2
Evo skis 11.0
Pounds gained 1.2
![20191220_202840.jpg 20191220_202840.jpg](https://www.snowest.com/forum/data/attachments/281/281614-a504e2693950770c37814552740825d3.jpg)
