Got my 2011 motor out and pulled part,mag side lower rod bearing gone.Feels like at least one crank bearing dragging heavy als
iler had been turned up since the start,case is ok.It was low on coolant,i talked to indy dan and he said he has seen a lot same way,that the water pump seal will leak coolant into case and it takes out mag side rod bearing.Rest of motor looked fine.2700 miles.. Freaking polaris
