Like new 2008 Trac Pac trailer for sale
I am selling my like new Trac Pac two place snowmobile trailer.
Used it for one short trip, and then bought a truck with a sled deck so no need to keep the trailer.
Purchased the trailer last spring and it is a 2008 model.
It has lots off acc added to it, and is in better than new shape with the features that have been added to it.
I am asking $2000.00 or best offer.
My name is Grant and you can reach me at 360.319.8922
The trailer is located in Bellingham WA.
Here is some info from the Trac Pac site:
For over 40 years, the classic TRAC PAC Snowmobile Trailers still lead the industry in high quality, strength and durability which are necessary to withstand the demands of heavy use and challenges of the seasons.
The trailers are made from tubular steel which provides more than adequate strength to carry full size snowmobiles and ATV’s.
TRAC PAC offers a smooth, more reliable ride with axles that exceed the rating to insure the load has margin of safety for added safety and comfort.
TRAC PAC trailers are hot dipped galvanized to give long lasting protection from road salts and chemicals. This quality coating, which is superior to paint, will keep its clean, durable appearance for many years.
The 5’ 4” tongue allows better cornering, easier removal of the sled and greater maneuverability of the trailer in tight spots.
TRAC PAC trailers are equipped with high quality, cambered, 3500# Dexter EZ lube axles and are proven time after time for their strength, lasting road reliability, and peace of mind.
TRAC PAC offers multiple tie down in front, mid point and rear for easy management of the payload and further use for ATV and utility applications.
The drive off front ramps are manufactured from tubular steel and installed with the end-user in mind. Not only are they available for the ease and convenience of off loading, but the shields protect the machines from salt, sand, gravel and other road hazards.
The aluminum side extrusion gives the TRAC PAC a distinctive signature look as well as the convenience of cleaning debris from boots.
All of our lights are inserted with weather guard grommets to insure long reliability. The rear of the trailer has added beaver tail to enable easy loading in any kind of weather.
The optional Load light can be added to the TRAC PAC to add lighting visibility and use in the early morning or late night loading circumstances.
The TRAC PAC comes in 3 standard sizes of 11ft, 18ft and 22ft.
• The user friendly drive on/drive off 2-Place RF11ILG individual loading tilt bed trailer provides for ease of use for one or two machines with enough room for an added toolbox or carrier.
• The RF11ILG weighs approximately 780# and is equipped with 10” C-rated tires which yield a carrying capacity of 1,430#. 10” E-rated and 13” B-rated tire upgrades are available.
• Total dimensions are 8’5” x 18’ 5”. Individual bed size is 4’ x 10’
• The drive on/drive off 3-Place RF18G is a non-tilting, full size multiple machine carrier with a movable rear ramp that stores securely under
the deck.
• The RF18G weighs approximately 900# and is equipped with 10” E-rated tires which yield a carrying capacity of 2,090#. 14” Lo Pro tire upgrade is available.
• Total dimensions are 8’5” x 23’11”. Bed length is 17’
• The drive on/drive off 4-Place RF22ILG individual loading tilt bed trailer offers the ease of loading and unloading of multiple machines and added cargo and storage.
• The RF22ILG weighs approximately 1,600# and is equipped with 13” B-rated tires which yield a carrying capacity of 2,820#. 14” Lo Pro tire upgrade is available.
• Total dimensions are 8’5” x 29’6”. Bed length is 23’
TRAC PAC is backed by our one year parts and labor warranty and our uncompromising commitment to customer satisfaction.
RF11ILG
Two Place Split Bed/ Tilt
Drive on / Drive Off
Heavy Duty Tubular Steel Construction
2210 lb. Capacity
780 pds. Dry Weight
10" C Rated Tires
Single 3500 lb. Dexter EZ Lube Axle
Full Lighting
Hot Dipped Galvanized
OPTIONS:
Tongue Jack
Spare Tire
Spare Tire Carrier
13" Tires/ Wheels
