I've got a 96 ZR440 Arctic Cat and I started off having periodic handwarmer issues (works one time not the next). Then on my second to last ride the RPM indicator stopped working but the lights and speedometer were fine. Now they went out too. The oil temp light and high beam indicator don't work either. The engine starts and idles fine. As for performance on the last ride it seemed to bog down some until I pumped the throttle a bit.
Any ideas as to what is causing this? I checked all the wiring and everything appears to be connected with the exception of the wire behind the dash that the AC dealer disconnected as it had idle problems- ran fine for couple months after dealer did this and never affected any of the other electrical items. Thanks for your help.
