Was out for a ride last night and every once and awhile the lights and gauges would shut off and it would act like it was restarting and then it would run fine for awhile and do it again It never did shut completely off though. Any ideas???? Thanks
Is it idling really slow at the times it happens? If so, is it when the engine is cold (after a lunch break or something) or just at random?
TPS sensor adjustment would be the first thing I would check, it can cause a low idle and trip off the Chassis Power Relay below about 900 RPM.
when it is running, does the battery show full power on the gauges? if not, the capacitor is bad.
It just happens randomly when riding when I'm partial throttle or sometimes when I wud hit a bump sometimes not.
OK il have to try and get a tool or make one thanks
Chassis relay will kill the lights and gauges if its bad. Could be loose or going bad
