cost is something they are going to have to determine. Their watercraft stuff is around 3K. I suggested they might need to be in the 2500 range. As usual you get what you pay for.
Is the impulse box a stand alone or a piggyback system? After you work with a stand alone you will realize the piggyback systems don't do much. For instance on my turbo sled I'm mapping to RPM/Manifold pressure/throttle position with compensation for air temp and engine temp. The ECU controls the wastegate and keeps the boost where I want it. Timing maps can have all the same comps. Want to change the rev limit, no problem.
Want to see what your engine is doing, just download the data and have a look. See attached photo.
New to motec is a knock module which will allow you to tune right to the edge of detonation, no more guessing. If you get some bad fuel and the module hears knock it will pull out whatever amount of timing you want.
