I just recently converted my 27ft enclosed bumper pull to a gooseneck hitch, should def help with towing
How in the world do you figure you might get any better fuel milleage?
I'm not buyin' that. How much closer to the P-up do you think your going to get? 6 inches. Looks to me like it would actually be farther from the pickup. Not only the fact that adding anything to the v in front will add weight (not to mention the weight of the gooseneck) which will drag down your fuel economy, the extra will act like a sail in a cross wind, actually lowering the milleage. Better fuel milleage, not a chance.closer to the truck as well as having a bigger V in the front to split the wind better. also your truck should ride more level.
I dont think there is any advantage to doing this other than cool factor.A sled trailer is light, its not like your pulling a stock trailer full of cattle.HTML:If you had to turn around in a tight spot might be an advantage there too.[/QUOTE]
Yeah I'll buy that, it looks like you could turn one around in a garbage can.
