C
Hi guys!
Pls help, installed LED light, but noticed that both beams working same time no matter which mode is on, high beam or low beam. Panel's high beam sign is also illuminate, no matter LED lights attached or not. As soon as I attach halogen, all works well.
Pls advise, is this thing named "heater indicator lamp in switch" connected with both wires, can be the reason of current flowing in both lines in case of higher resistance when Led or nothing att-d? What is it BTW? Can it be removed?
Leds lights now without decoder, anybody expereinced, will it help if I buy it and it solved this matter? Decoder works as low resistanse trick?
Tnx in adv!
Tnx in adv!
