C
ClimbHigh
I have a M-7 that had been moded with a big bore M-8 by Cat dealer as a demo sled I had to rebuild top end and converted back to completely stock M-7 except for larger air intake and reflashed ECU markings on ecu are TTIMP1 if this means any thing to an Arctic Cat gue rue. I was told by dealer this was a race ecu flash.
Now the question to you guys is, am I running to lean or not. I put new spark plugs in ran sled about 40 miles fairly hard pulled plugs and not much color change in porcelain, but Y pipe seamed oily not dry. Porcelain is not tan, but with synthetic oils I thought this may not be correct way to check. I run Blue marble oil if this makes a differance.
Thanks for input
